Central air unit
I have a 2 ton central air unit that is used for cooling my mobil home.My qustion is how can I order a new compresser for it ?Or can it be order here? If so how much does it cost and how do I install it? What information do you need to order it?
the easy part first....
yes you can order one. that is the easy part, look at @300 plus or minus depending on type and model. no, you cannot put in yourself, but an a/c guy will do it pretty cheap on the side. look for any where of 200 and up plus compressor
