Heat Pump won't come on all the time
I have a heat pump that won't come on unless I slide the temp control up and down real fast a couple of times. It then comes on and starts cooling but once it reaches temperature and cuts off it won't come back on again unless I do the same thing again. Any ideas as to what may be the problem. I replaced the thermostat and it didn't help.
Thanks
Ed
Thanks
Ed
A possibility if you have an older unit:
You need to give us information about your unit: Model #, Age, Size, Type (AC, HP, Cooling only, package unit or split. etc.
Some older units have a lockout circuit that prevents operation after a safety device shuts it off for some reason. The reset is to turn the stat off and on or turn the power off and on. Next time try turning the power off and on to see if that will restore operation.
wiring
Go outside and see if the voltage is zero between the red to yellow low voltage wiring....it should be,... (when in the on position)
Received 1 Upvote
1 Post
A/C
Turn the power off before you go in there if you dont know electric. There should be like a service panel there above where the copper lines come out of the unit That is where you have to go. Some of the old ones you have to take the top off with the fan in it to get to them.Look around where the wires go in ED
