conderser plugged up
my blower unit is in the basement with a pvc pipe coming from it. had some water backed up a few days ago so i blew it out with a buddies air compresser. thought this had fixed it but there is more water today. is there a more permanent fix to this? i plugged up all the lines that i could find to make the blast of air do the most good. thanks for the help.
big wally59:
You will have to investigate further to find out where the water is coming from.
The ductwork will have to be opened up to check out the evaperator coil.
This morning's job for me was to replace an evaperator due to a rusted drain pan.
