Payne A/C Heat Pump
Old 08-01-03, 07:55 AM
vjdcosmo
Question Payne A/C Heat Pump
I had local shop replace a Lenox 3 ton A/C Heat pump with a Panye PH 10 A/C Heat Pump. Now for the question: I live in Houston and yes it is humid all time but the old Lenox could dry the air to about 40% humidity level. The new system runs forever and can only get the humidity in the house down to about 65-70%. I have had the tech back twice and no results. Help. Thanks
vdico@aol.com
Old 08-01-03, 01:36 PM
hvac4u's Avatar
did you change the inside too?
drop the fan speed a notch, increasing latent heat removal. may be set too high
