air conditionor
Old 08-04-03, 07:52 AM
scottie
Question air conditionor
My a/c unit is blowing out lukewarm air. I went outside to look at the unit, and the fan was not working. I went inside the house and shut off the unit, at the thermostat, and waited a minite, and then cut on the unit and it started to work with cold air. After sometime, the unit started blowing lukewarm air, went outside and sure-nuff the fan was not working. So, I did the same thing and shut off the unit, waited a minite, and cut on the unit and it started working again. what do u think the problem is?
thanks scottie
Old 08-04-03, 08:35 AM
mattison's Avatar
Can you tell if the compressor in the outdoor unit is running when the fan stops or does the whole outdoor unit shut down compressor and fan?
Old 08-04-03, 11:37 AM
scottie
Question aircondition
mattison,
thanks for responding, yes the conpressor and fan and all shuts down, except the blower again thanks
