drip pan
Old 08-11-03, 09:19 PM
packfan1967
drip pan
Here is my problem. The drip pan under my unit in the attic is not draining. I cut the pvc and blew in both directions (towards the unit and towards the drain) and they were both clear. Hooked pvc back up using a 3/4 inch elbow and the pan will still not drain. The pan is holding water and does not leak but now I have a foul odor (I'm geussing mildew???) The crawl space is very tight and I can't get a shop vac up there to suck the water out. I tried soaking it up with towels but it only fills back up when I run the unit. I have been running it a bit at night to keep my son's room cool. Any thoughts on why it won't drain even though I can blow through the pipes easily? Any suugestions would be appreciated.
Old 08-12-03, 08:58 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
A/C drip pan
Well first why is there water in the pan now??????Dont the coil unit dran???????????????? Is there no water comeing out the units drain pipe????Do you know where it is?. On the pan under the unit does its pvc pipe go up hill and it dont drain? Need more info here. ED
Old 08-12-03, 10:23 AM
packfan1967
more info
The coil drain is fine. The unit is a couple of years old and I've never had a problem until recently. I did lower the drain end about 1 1/2 inches and I placed a level on it to make sure it was running downhill. This whole thing has me stumped.
Old 08-12-03, 11:34 AM
Ed Imeduc's Avatar
drain pan
Lost here==== You made the dran pan 1 1/2" lower on the drain end. Did you lower the whole pipe line from it also??????? You say the coil drain it fine. Then where is this water comeing from.Is there any ice on the big line there or on the coil???Im back to why is there water in this overflow pan . ED
