no air conditioning or heating
Old 08-21-03, 07:03 PM
Hi, I own a 1 1/2 storey approximately 53 years old. just today after coming home from work,I discovered that my a/c was not working. I checked the thermostat and it was set to cooling at approximately 20 degrees celcius. The house was warmer than usual so I turned the thermostat down cooler. After about 5 minutes the a/c had not started, the temperature on the thermostat read 25 degrees. The furnace fan did not turn on to blow air, I checked the breaker and it was not tripped. I then turned the thermostat to heat and set the temp. to 30+ degrees and waited. The furnace did not turn on( gas or fan), I also checked the furnace breaker it was not tripped. The a/c unit is 6 years old Carrier model#38TKB018300 1 1/2 ton. The furnace is gas/electric, Lennox model#G803-90-2. I do not know it's age as it was in the house when purchased in 96. However the house inspector estimated it's age at 12 years in 96. The pilot light is lit. I do not know the make of the thermostat, but it is a mercury switch type ( 1E56W-329) written on inside of thermostat cover. I think its the thermostat any ideas? Sorry for being long winded
Richard
Old 08-22-03, 04:24 AM
mattison's Avatar
There should be a switch on the side of the furnace that someone could have turned off.
At the t-stat put the fan switch to on. Does the inside fan come on then?
Old 08-22-03, 02:55 PM
Hi, thanks for the reply,I feel like an idiot! I forgot about the switch for the furnace. On the way to work this morning I noticed it was turned to off,must of got bumped.
Richard
Old 08-23-03, 02:27 PM
Ed Imeduc's Avatar
switch
Hey dont feel bad .Hate to tell you how many service calls I have gone on and its just the switch. The other best one is they turned the tstat the wrong way up or down and the unit dont come on to get heat or cool ED
