water dripping from inside heatpump unit
Old 08-23-03, 04:28 PM
bfurlow
Water is streaming from inside heat pump unit into
drip pan every time unit kicks off, instead of going
out the piping to the outside.
Old 08-23-03, 05:23 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
water
Do you have a trap in the drain line there? is the pipe PVC . you can cut it near the unit and blow both ways in the pipe. just put the pipe back with a pvc coupling or you can go out side I think you said and blow back from there and see if it will open up the drain pipe. if you cant blow in the pipe you can try a shop Vac and see if it can blow back in the drain line or suck it ED
