forced hot air
the furnace is a 2 year old armstrong sx ultra 80 gas furnace. The problem is the burners kick on then the blower about 60 sec. later. The blower then shuts down for approximately 3 to 5 min. regardless of how many cycles the burners fire. sometimes the burners fire 2 or 3 times before the blower comes on again. I've tried all three speeds on the blower and the higher the speed the quiker it shuts down. Any thoughts???
Hello: Riff
There are several possibilities causing the cycling. Without more specific information, it would be almost impossible to list all them here.
A two year old furnace should have a spark ignitor or a glow coil to light the pilot. It could be one of these or there circuits causing the problem. It could also be a defective fan switch or a safety device shuting the furnace down.
With these new models it takes the correct diagnosic equipment and a trained expert, in most cases, to correct problems.
A two year old gas fired furnace should still be under a warranty. Contact the installer or the authorized repair agency for the needed fix.
Good Luck
Sincerely,
TomBartco
TomBartco Enterprises.
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
E-Mail:TomBartco@doityourself.com
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Good Luck
Sincerely,
TomBartco
Personal Quote:
