not getting enough heat/air
We live in a 2400 sq.ft. ranch home. The furnace is located in the basement. We have one room in the house that doesn't get much heat or air. The furnace/AC units are both new-the best Carrier units that you can buy, and most efficient. Has anyone had any experience with adding a booster fan? This has been recommended, but no one seems to know if this will work? Any other ideas? We are tired of being cold and hot in the wrong seasons. This is the room that we spend all of our time in!
Hi aisy
Try closing <about half way or more> some of the other register vents in the warmer rooms.
You can close one vent totally, if there is a room with two vents that gets too warm.
The idea here is to reduce the volume of warm air in any room that is too warm, has more then one vent and/or is closest to the heater.
This will shift more warm air to the cooler rooms while reducing it in the warmer rooms. Try this first, before adding other possibly un-needed equipment like duct fans, etc.
Good Luck
Sincerely,
TomBartco
TomBartco Enterprises.
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Good Luck
Sincerely,
TomBartco
Personal Quote:
