A\C Unit not turning off
Old 06-12-00, 06:05 AM
Guest
Unhappy
My central air unit is continually staying on no matter what the thermostat is set to. The furnace fan appears to be turning off and on correctly, so I don't think it's the thermostat wiring. I'm having to shut off power to the unit at the breaker box. Any help would be greatly appreciated.
Old 06-12-00, 08:06 AM
Guest
Post
If no wiring or parts have been changed since it worked right last it must be a stck or welded contactor on the outdoor unit or a short in the low voltage wiring between the furnace and the outdoor unit.
Old 06-12-00, 10:40 AM
Guest
Post
Hi TK00,
Thank you for your quick reply. Can I safely assume that since I switched off the breaker on the side of the furnace (the one that looks like a light switch) and the A\C unit kept running, that the problem is a frozen connection on the unit?
Thanks
Corey
Old 06-13-00, 06:47 AM
Guest
Post
yes.... the low voltage from the furnace to your outside unit is what controls the contactor.. sounds like you need to have it checked out.
