what next with radiant heat
I recently had radiant hot water floor heating tubes installed in my garage and was told that I could use a hot water heater instead of a boiler. Is this true and if so what would be my next step after running the tubing and buying the hot water heater?
miglarsh:
A hot water tank would likely work as long as it has the btu capacity to heat the space.
I have seen people do this but one thing that I don't care for is the amount of water you are heating and keeping in storage.
A proper boiler is very small and only holds a couple of gallons.
Instructions on how to hook this up would depend on how the tubing was installed in the floor and what climate you live in.
If you live in a very cold area you may want to use a closed loop system with heating anti-freeze in the lines.
Give us more details like where you live, size and insulation in the garage, type of fuel you plan to use, amount of tubing installed in the floor and whether or not it is one big loop or there are several ccts of tubing.
Depending
On lacation, size of home heat load etc you may be able to do as I did and use the same water heater for heat and Hot water.
For our 2 bedroom house in Oklahoma it works great
miglarsh:
If insulated a space that small will take very little heat but if in your climate there is the possibility the floor could freeze, you will have to use glycol in a closed loop system.
If the floor does freeze using water, you would do serious damage to the floor.
A space this small I wonder whether in-floor heat is economicaly worthwhile.
