90 psi - 260 head pressure
MY A/C HAS A HARD TIME BRINGING MY TEMP. DOWN TO 77 DURING THE DAY.I TOOK A TEMP. AT SUPPLY IS 66 AND RETURN IS 76.I NOTICE THAT THE SUCTION SIDE NEEDLE MOVES UP ALITTLE.COULD I BE OVER CHARGE,IF I RECLAIM FREON FROM SYSTEM MY SUCTION LINE TEMP. GOES UP.ANY SUGGESTONS. THANK YOU
in response to your question about your pressures/temp.
your system sounds like it is low on freon, not to much.
You should have a high and low pressure side and by the sounds of it you you only have a low all the time.
you need enough freon so that when it passes through the orifice it will expand into a low heat low pressure gas.!
email me if you want and give me more details on your system.
rheahterington@hotmail.com
