Thermostat
Old 07-18-00, 11:47 AM
Post
I have aHoneywell thermostat and i like to change to a White Rodger but
do not have the wiring diagram it is for heat and cooling can you help
Thank you....Spike
Old 07-18-00, 04:41 PM
Post
hello spike im moveing your post to heating and air they r much better qualified to answetr this ?. look for replys there
Old 07-18-00, 08:48 PM
Lightbulb
Hi:spikea
Look closely on the back of the new thermostat. You will see tiny letters near the terminals indicating the color of the wire to connect to that terminal.
Example: R=red and Y=yellow
Connect the wires extending out from the wall to the appropriate terminals on the thermostat based on their colors.
Good Luck,
TomBartco
Old 07-19-00, 05:03 AM
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by TomBartco:
Hi:spikea
P S I try that but did not work The honeywell has a jumper for the letter R and RH the Rodger do not have the letter RH .Thank you
Good Luck,
TomBartco
<HR></BLOCKQUOTE>
