Central A/C Squeking
Old 07-31-00, 08:51 PM
Guest
Post
Elec. central A/C unit outside is squeaking intermittantly. Neighbor called first time, it had stopped by the time I got outside. Later, I heard it...sounds like squeking belt, bearing?? Anything I can do myself or do I open my wallet and bend over?
Thanks,
Old 08-01-00, 01:01 PM
Guest
Post
This could be coming from the fan motor itself. You could try adding oil to the motor and shaft. Find the tiny holes marked on the fan motor , use good quality fan motor oil. I am not familiar with belt driven condenser fans. If you have one, check belt. Make sure you turn off ALL power to the complete unit, inside and outside.
Old 08-01-00, 05:05 PM
Guest
Smile
Thanks Joe, I'll try it. I appreciate your prompt reply.
Hound Master
