What to do in Blower Closet?
I am about to have my heat pump replaced. It has an outside unit and an inside unit in a hall closet. The closet wall has drywall, but it was not taped or painted.
What, if anything, should I do inside that closet while the old unit is out of there?
My main concern is checking for possible air leaks - don't want that unit pulling in hot air from the attic.
It don't matter.. You can do what ever you want..
If it was mine, I would tape, and paint it up to make it look nice for the new system.
Also, will you have enough time in between to do everything?
