heat and ac leakage
Old 10-24-03, 10:17 PM
harrodo
heat and ac leakage
I live in a 1973 silver crest moble home there to be a problem with my heater and ac system the heat and ac comes out at the attic vent on one side of the house this house is a doble wide also heat and ac comes out of the vents in the heater and ac compartment how can i find were the leak is ? thank you harrodo
Old 10-25-03, 05:35 AM
GregH's Avatar
Super Moderator
Received 8 Votes on 8 Posts
Question Not too clear on the problem.
Is it that you feel air flow out of the attic vents when the blower is turned on?
Go here for what would be good to know.
Old 10-26-03, 10:16 AM
harrodo
air duck linkage
To GregH...HVAC Tech Yes I can feel the heat and the ac comming from the attic vents I think there is a linkage in the duck work where the heater is connected I need to know if it can be fixed without removing the evaporator from the top a the heater thank you harry
