Base board heating
Old 10-25-03, 09:28 PM
mkaur
Base board heating
Hi,
I had recently turned off heating in the house to air it out. When I restarted it, one area in the 2nd floor (master bed and bath) did not warm up like the rest of the house. Cant hear any water in the pipes either.
Am new to this kind of heat. Rest of house is OK. Pump is sending water in other areas (baseboards are warm to touch).
Any ideas?? It is a single pump, with 2 zones, 2 thermostats.
Old 10-26-03, 06:01 AM
KField's Avatar
There is no reason that turning off the heat would cause this problem so it may not be obvious how to solve it. If your zoning is done with circulators, one may be defective. If it is done with zone valves, one may be defective. Air may have accumulated in that zone and is preventing circulation. Other than that, there is no reason for lack of heat after turning system back on.
Ken
Keep in mind that the more background info you give us, the better and faster we can point you to the source of the problem.
Old 10-26-03, 07:29 AM
Ed Imeduc's Avatar
boiler
With Ken here more info will help. Is there a bleeder up there?have you tried to bleed that zone ? ED
