Base board heating
Old 10-26-03, 05:10 PM
mag330
Base board heating
Gas fired baseboard system temperture only goes to 130 degrees no mater what temperture you set the thermostat it will not go past 70. How do you increase the boiler temperture to 140 -180.
Old 10-27-03, 05:54 AM
Ed Imeduc's Avatar
Question boiler
If the tstat turns on the pump for more heat. Then there can be on the boiler a aquastat .Most of the time its set for 180o this is what would turn the burner on. Id say look there. ED
