Central A/C Unit Outside Wont Shut Off
Old 08-17-00, 11:10 PM
Guest
Post
My central air unit outside runs continuously. The fan inside seems like it works fine, it has very cold air and cools the house perfectly. I noticed today though that when the inside fan kicked off, I could still here the fan on the outside unit running and I cant get it to go off? Any help would be greatly appreciated. THANKS!
Old 08-18-00, 04:18 AM
Guest
Post
Hi Bill:
Try turning the system off at the thermostat. If the outdoor section is still running, most likely what's happening is the contact points on the compressor contactor are stuck shut. Could also be a thermostat problem, but check the contactor first. Thanks. John.
Old 08-18-00, 11:31 PM
Guest
Thumbs up
John,
that was is it, it's now fixed and working perfectly. THANK YOU!
Old 08-19-00, 04:51 AM
Guest
Post
Hi Bill:
You're welcome sir. It's a good thing you noticed that the unit kept running. Unattended, it would have wiped out the compressor causing extreme wallet pain. Thanks. John.
