heating and cooling
heating and cooling
I'm having a heating and cooling problem. Nothing happens when I set the thermostat on anything, "No Blower, No AC, No heat".
I replaced the thermostat and nothing changed.
I live in a moble home and have had problems with mice and rats coming into the house where the blower unit is and I did find where they chewed the housing off 2 wires that come from the ac unit to the blower unit and those 2 now bare wires were touching, "1 of those wires conects to 1 of the 5 thermostate wires".
I have replaced those wires and still nothing happens.
I sure could use a little help, Thanks ,,,, Keith
The heating unit is all electric by "Intertherm", I'm having trouble finding finding the model number but I do have a digital camera and it would just take a few minutes to take a picture of the inside, I have all of the covers off showing the blower and the wiring to the heating panel, just let me know and I'll have that picture in a quick minute.
Thanks for helping me out,,,,, Keith
furnace
Well we can try this at the tstat pull the wires off mark them down. Now take R should be red and put it to G the fan should come on?????? Is this a heat pump or just electric heat. How do you know there is power to the outside.
ED
I checked the AC unit outside by pushing in on this magnetic like connector with a screw driver and the unit came on.
I'm not sure what the tstat is but I have the red and green wires I think your talking about marked out but before I put them togeather I wanted to check first, " Both the RED and Green wires I've marked are connected to several wires leading from the thermostate," I hate to send sparks flying!!!!!
FURNACE
The R to the G should just turn fan on. This is only 24 volts there it wont hurt you.
ED
the tstat means thermostat take the wires off it and put the R to the G and see if you get fan only
That was a nifty little reply you had, I guess you didn't fall for the sparks alibi.
I put the 2 wires togeather and nothing happened, not a sound!!
I took a picture of the unit and posted it, Were you able to see it?? It showed everything there pretty clear???
FURNACE
picture wont do it. Have to know if you have power.Get a volt meter or small multitester $10.00 so you can ring the unit out. Or turn the power off to the whole unit and pull the transformer and get a new one and then see what we have and if thats it.
ED
I suspect the problem is either with the wires you replaced or that the control transformer was burned when the wires got shorted. Like Ed is saying, you need to be able to trace voltage before you can pinpoint the problem.
Ken
Ken
