Baseboard heat
Old 09-24-00, 06:36 PM
Guest
Post
How do I calculate the length (amount) of baseboard units required to heat a basement we're refinishing (gas heat - forced hot water)?
Old 09-24-00, 08:43 PM
Guest
Post
First run a heat load on the space, then you figure the amount of BTU's need per room and find what the output of the Baseboard is at a set temp and figure the amount of feet needed..... or you could guess and just add it along all the outside walls...the best way would be get a plumber or heating contractor in there and figure it up for you
Old 09-25-00, 06:26 PM
Guest
Post
Hi Jane:
The baseboard heat experts are at www.heatinghelp.com You'll find a message board and also some inexpensive books for sale that will answer your questions and more. Thanks. John.
