Furnice is spewing hot water
I appologise if this is not the correct forum for this question. My furnice started spweing hot water from an overflow all over my cellar. Everything heats fine, we have hot water and it has been cleaned regularly. It seems to only happen when I turn the heat up a bit in the house. I'm at a loss what would cause this. Thanks for you help.
Not sure just what you have there . But get that boiler temp down now for sure. Like 180o to 200o now now now. Check the limit or immersion control on this boiler now. The max temp on Most pressure safety relief valves is at 30 psi and 250o temp
ED
You have a problem on your hands that you do not want to let go too long. If you can't find out what is wrong by yourself today, get it looked at by a professional tomorrow. There is no high temp safety on the relief valve, only pressure. What that means is that you are building pressure by boiling water in a boiler that is not meant to boil water. You will do permanent damage if that goes on for more than a few hours. It sounds like a high limit is not opening up when it should. That is unusual but I have had it happen. You could turn up the thermostat and watch the pressure and temperature while staying away from the safety valve discharge. If there is boiling going on, you should hear some thumping going on inside the boiler. Turn it off at that point and note any temperature over 220.
Don't risk major damage to save a few bucks.
Ken
Ken
