electric heat and air
Old 12-01-03, 07:22 AM
jomom44
Unhappy electric heat and air
Please help
My unit will only work on cool. not heat. This happened before and I believe it was a relay switch. I would like to know how I can change it myself. I know it is located in the air handler.
Can anyone help me? We are freezing!!!
Old 12-01-03, 08:53 AM
mattison's Avatar
Received 1 Upvote on 1 Post
When you turn the t-stat to heat and turn it up to say 75 does it do anything? Have you checked the breaker? Changed the filter?
Old 12-01-03, 10:41 AM
Ed Imeduc's Avatar
Question heat
Is this a heatpump or a unit with just electric strips for the heat in it. On the door of the unit should be a wire layout of the unit. You might find what relay it is there. The 24 volt common and white should be on the heat relay. ED
