No heat from electric furnace, won't come on
Old 10-08-00, 03:32 PM
Guest
Post
When the thermostat is turned to heat, nothing happens when the fan is on auto. When the fan is turned to the on position, it immedeatly comes on but the air is not hot. The A/C works fine.
Old 10-08-00, 03:48 PM
Guest
Post
Hi Jordans:
Assuming that you haven't replaced the thermostat, the problem is most likely a bad sequencer in the furnace. Look down a few posts and you'll find a lengthy post where I wrote about how to troubleshoot an electric furnace. If you need further help, give a holler. Thanks. John.
