installing thermostat
I want to move my thermostat from downstairs apartment to upstairs apartment. I already snaked the wires but am unsure how to connect the wires on the furnace side. I notice near the furnace a honeywell transformer with two wires (covered with tape) attached to two screws. Is this where the thermostat wires shouild be connected?
Hi david:
There should be a cable coming into the furnace from the downstairs t-stat. Just mimic the connections on your new cable, changing the wires over one at a time. Then got to the downstairs t-stat and make a sketch of which color wire goes to which terminal. Go to the other t-stat and make the same hookup. Then operate all cycles to make sure everything works properly. Should be easy. Thanks. John.
