Hot water heat stays on after stat turned off
Old 01-03-04, 07:56 PM
gavzilla
I have a Crown Boiler system, Gas fed, with an indirect water tank.
The problem is after I turn off the thermostat, [heat only thermostat] the heat stays on, I disconected the stat , unhooked the wires, and it still stays on.
The systen has only one zone, or pump.
Any Ideas?
Thanks.
Old 01-03-04, 09:13 PM
A
Received 1 Upvote on 1 Post
Are you saying that the gas to the boiler, keeps burning even with the thermostat wires disconnected, and that it will never shut off? Or, does the circulator pump just keep running?
Old 01-04-04, 07:58 AM
gavzilla
When the termo is disconected, heat still comes from hot water base board.
I noticed problem when thermo was turned off, and heat still came up.
After disconecting thermo wires, I left them disconectd for at least 5 mins, and heat was just as strong..... [even felt pipes underneath, mad hot] .
During summer months, spring, etc, boiler is always "on" as it makes hot water for the "indirect hot water tank.
Tested the wires going to the stat, getting the 24 volts that I should.
I would imagine pump is running constantly, no matter what, as heat is ever present?
Thanks for any help.
Old 01-04-04, 08:04 AM
Ed Imeduc's Avatar
Question boiler
INFO INFO is the pump running with the wires off the tstat?
Is the burner on at this time also? Is this your first time with hot water boiler????? ED
Old 01-04-04, 12:11 PM
gavzilla
Re: boiler
Yes, the pump is running with the thermostat off.
No, I don't have much expierience with boilers.
Old 01-04-04, 04:56 PM
Ed Imeduc's Avatar
Lightbulb pump
If you take the 24 volt wires off the pump does it stay on??? ED
