Heat
Old 01-05-04, 06:25 PM
Fastlane33
Heat
I have hot water baseboard heating in my ranch home. Currently, there is heat only coming from 1 of the rooms. There are 7 other heaters that are not getting hot.
When I turn the nozzle to bleed the system, I get a bit of air, but barely any water coming out and when it does the water is cold.
I am at a loss for what is wrong. Can someone please help?
Thanks in advace,
John
Old 01-05-04, 07:41 PM
KField's Avatar
It could be a problem with the circulating pump. Can you find it and check it. It should be right near the boiler in the piping and will have a wire running to it.
When you bleed the system be sure to have the thermostat turned down so that the circulator is not running. If you get any water, you have bled enough.
