on and off constantly
Old 01-08-04, 03:35 PM
dennist 1
It goes on and off constantly and my furnace is 1 yr old gas, its cold
Old 01-08-04, 03:45 PM
hvac4u's Avatar
change the filter..... what goes on and off?
Old 01-08-04, 04:13 PM
dennist 1
filters new . the fan clicks on for 2min then goes off for 2 min it seems like it doesnt even get to the temp set
Old 01-08-04, 04:27 PM
hvac4u's Avatar
gotta know.... make, model, where it is located, type of gas (nat or lp). desceribe the sequence, this will help a lot
Old 01-08-04, 05:27 PM
H
Received 1 Upvote on 1 Post
heat anticipator
sounds like the heat anticipator was never set. Is it the round mercury style?
Old 01-08-04, 06:32 PM
Ed Imeduc's Avatar
Lightbulb ???????????
You dont say if its the gas that is going off and on or just the blower that is going on and off. I year old is this then the first time for heat on? like they say INFO INFO will help. ED
Old 01-09-04, 05:44 AM
G
Mine does the same thing but it is an older furnace. I believe it is my anticipator. I know on the old round mechanical thermostats that it is adjustable... but how do you adjust it on a new Honeywell programmable one??
Old 01-09-04, 05:49 AM
mattison's Avatar
1 Year old should be under warranty and messing with may void it.
If it's not under warranty we need as much info as possible. Is the burner kicking on & off also?
Old 01-09-04, 09:16 AM
dennist 1
Im getting the info on the furnace, Its not even mine so bare with me. And yeah burner is going on . Thanks guys
Old 01-09-04, 03:19 PM
H
programmables
I don't believe they are adjustable, they use a learning curve...fuzzy logic.
If you have the old mercury round thermostat set too low, the thermostat will shut the heat off even when the temp is never reached. They use a variable resistance heater on the heating side. The cooling side is fixed with a resistor. You can set it to match the gas valve amp draw, or check it with an ammeter.
