Furnace cycling on and off
Old 01-10-04, 06:50 AM
kcaklm
Angry Furnace cycling on and off
I have a Carrier gas furnace that's about 7 yrs. old. It's controled by a Honeywell programable electronic thermostat (7 yrs also) What happens is the furnace will come on and run for about 5 min. It turns off, and then within 5 seconds it comes back on and runs for about another 2 min. and then shuts off normally. When it shuts off the second time, it does not come back on till the thermostat normally turns it back on. Is this a problem with the thermostat or the heater? What should I check??? Thanks for any help.
Old 01-10-04, 07:14 AM
hvac4u's Avatar
jump r and w low voltage terminals at the furnace, if problem continues, rule out tstat
Old 01-10-04, 07:26 AM
kcaklm
How long should I leave this jumped for? What does this do ?
Old 01-10-04, 07:38 AM
hvac4u's Avatar
jumping r and w bypasses the tstat, if the problem usually occurs after 5min, leave the jumper on for 10min
Old 01-10-04, 07:45 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Lightbulb fliters
The fliters and AC coil are clean on this unit??????? ED
Old 01-10-04, 07:46 AM
hvac4u's Avatar
good point, ed it may be going out on hi limit
