B-Vent for furnace
B-Vent for furnace
Hello All,
The duct work is in now on the gibson kg6ra045 furnace
I was installing 2 lengths of b-vent one 5' and one 2' peice of vent pipe.
a friend came over he said I needed a draft hood connector at the top of the furnace vent then put on the vent pipe through roof.
Is that correct or can I just put the lengths of b-vent on top of furnace and thru roof with flashing and storm collar and wind cap?
thanks in advance
thanks in advance
Not where you system is set up.. But you can use the regluar pipe, and use the B-vent when your near combustable products.
Don't need to use scew on b-vent tey should twist and lock in place.
But yeah. put the pipe right on the furnace, and off to the roof you go.
code here allows 14 in single wall as long as 6 in min clearance to combustinles is met, NO screws in double wall, if so the must be stainless if they penetrate the inside liner.
