Hydronic Switching Relay for heating house
I had posted a question this morning concerning the heating system for my house...however, the post appears to have been deleted. The gist of the question is that one of the four Honeywell Hydronic Switching Relays that controls one of the water pumps that circulates hot water through the radiators in the house short circuited. I have had no success in finding a replacement for this Hydronic Switching Relay R882C from Honeywell. They suggested some Honeywell dealers in my area (Boston), who have indicated that they don't have this part. Where can I look for a similar part, or how do I find a suitable replacement? Was my post deleted because this is an inappropriate forum for this question?
thanks,
Ken
thanks,
Ken
Try looking in your yellow pages under plumbing and heating supplies...when you talk to someone at the counter, tell them you need a switching relay for 24 vac thermostat control of line voltage (circulator) devices. There are several out there that will do the trick.
Good luck
Chris Jones
candcjones@catskill.net
Good luck
Chris Jones
Hi Ken:
Your post was deleted when I tried submiting a reply yesterday. I dont know why, but it happens occasionally. I found documents on both the old relay and a replacement at Honeywells' technical literature website. Go to http://hbctechlit.honeywell.com/ Click on model and type in r882. You should get 3 documents back as search results. Document # 95-6762 contains the old relay and #60-2481 contains a relay that is a current replacement. [R882J] You have to download the documents separately and you need Acrobat Reader. Thanks. John.
