Havent been around one. But have seen talk about them . The auger they said is small and if the corn has any junk in it that get in the auger and stop's it ED
Hi,
I have a bypass humidifier attached to my return plenum and have a 6" duct running to it from the supply plenum. I have a heat pump/electric coil sysytem.
I noticed in my humidifier manual to install a humidifier downstream from an Electronic Air Cleaner. But my humidifier is located a couple of feet ABOVE the EAC. How big of a problem is this since my humidifier is an evaporative type, and does not spray out water particles( I did have some water on the floor the other day and it came out of the bottom of the plenum because I believe my eveaporator pad which was over 1 year old clogged up.
Also what difference would using hot water in my humidifier make, since the heat produced by the heat pump/electric coil strips is not like oil or gas....
I hope I explained myself well, and can get some advise....Thanks.
George
p.s. or do I even need a humidifier because I have had it off for 2 days and present humidity is 25% and outdoor temp is 8F.Read More
