furnace gas will not come on
Old 01-25-04, 11:59 AM
jq593800
hello. my furnace is a york the model # is p3ucd12n07601a forced hot air. The thermostat is a manual. The exaust fan comes on the igniter comes on but the gas will not come on.
Old 01-26-04, 10:53 AM
HVACELECT
Re: furnace gas will not come on
did you pay the gas bill.
Mkae sure that the gas supply line is in the on postion this will be the valve located within 72 inches of the furnace it is usually right next to it after you check that check the furnace gas valve itself and make sure that it is in the on postin
Old 01-26-04, 01:36 PM
hvac4u's Avatar
if there is gas to the valve, check to see if the valve is getting power, if so bad valve, if not, problem may be the board. look for loose or burnt wires
