Zone valve replacement
I need to replace a Honeywell zone valve that has no inline shut off valve above it. Will all the water drain out of this zone if I dismantle the valve? If so, how do I put the water back in after I replace the valve?
If it is a newer V8043 you can replace the power head without draning the system.
http://hbctechlit.honeywell.com/tech...000s/A1228.pdf
Received 1 Upvote
1 Post
Power off on the boiler. Shut the water in valve off there at the auto fill valve. open the drain co** on the bottom of the boiler. open vents on the base board. Keep what water you can in the boiler just drain below where you have to work.
ED
