Heat pump blowing cold
Old 11-21-00, 10:15 AM
Post
I have a problem with my heat. The fan is working outside but it blows cold air inside. The a/c works fine. I haven't used the heat in 2 years. I recently replaced the outside fan motor. The a/c worked after replacement. How can I diagnois whats wrong?
Old 11-21-00, 01:19 PM
Thumbs down
i would not attempt to try and repair your self this is something that should be left to a pro in your area, it could be a bad stat, bad reversing valve and a few others
good luck call a pro
