York Diamond 80 Problems
Old 05-11-04, 06:51 PM
IFixIt
My York Diamond 80 won't light. Here is what has transpired:
It would run correctly, but kept blowing 10A fuses. I'd replace and it would run for a few hours and then blow fuse again.
This went on for a few days. Then, it wouldn't light. There is only one flash on the LED when it starts, then nothing. The ignitor glows red, but nothing else happens - no fan, no gas, no flame, and it won't cycle out of this mode - it just keeps on with the ignitor bright red.
I'm thinking the circuit board is blown, but how do I confirm this?
Old 05-13-04, 06:21 PM
hvac4u's Avatar
it is the board, have seen this more than a few times
Old 05-14-04, 03:19 PM
IFixIt
Thanks hvac4u for the reply.
Any clue why it would blow fuses? Something on the board drawing too much current?
thanks,
IFixIt
Old 05-14-04, 07:21 PM
hvac4u's Avatar
low volt short, probably in a fan relay.
in heat a lot of times it is the inducer motor relay.
i have fixed them in the past, now it is cheaper to replace the board
Old 05-16-04, 06:56 AM
IFixIt
Thanks for the replies. Seems to be be "new board time". I've found a local source (Denver area) where I can get the board for $180.
Old 05-16-04, 07:09 AM
hvac4u's Avatar
keep shooping, that is kind of pricey, although i pay wholesale (@$80)
Old 05-17-04, 01:29 PM
hvac4u's Avatar
Boy Are We Good!!!
i see where you posted this same problem on another site, and got the same answer. be careful over there they HATE diy'ers
