venting 90 % furnace
Old 06-07-04, 01:09 PM
washed_3981
My furnace is located in the center of my 1920 house. I'm going to install a 90 % furnce and I do not want to vent it through the roof. Can I run the vent pipe down under the house and through the foundation? Do I need a special blower or anything else? What brand of furnace would you recommend? Thank you Bill
Old 06-07-04, 02:45 PM
hvac4u's Avatar
as long as the flue pipe has a 1/4 in per ft fall back to the furnace, a sidewall vent is no problem. get them to run a fresh air intake as well, this will boost efficiency upt to 2 plus %. length and number of turns are essential info before installing. how far will it run and how many turns?
flue pipes never run down, if that is what you meant by "down under the house"
Old 06-07-04, 04:29 PM
washed_3981
thank you
Yes, I was hoping that the flue pipe could run under. Do you have any preferance in brands of furnaces? thank you Bill
Old 06-07-04, 05:26 PM
hvac4u's Avatar
my personal preference is amana, but rheem has a modulating furnace that is truly the best one out there
