Chronotherm III Thermostat
Old 08-10-04, 03:02 PM
SKCRNRDCMD
T8600C1014 has quit - frozen display with good batteries and AC power. Was wired W G R Rc Y. System is oil(high efficiency)/hydronic/air.
Presume both model # and wiring mean Heat and Cool are both single stage - correct ?
Which replacement, if Chronotherm IV ? Most Chrono III's for sale on Web give no model #.
If "Power stealing", do I need to find C(ommon) off both Heat and AC
transformer, or will just one do ? Any "jumpering" ?
Thanks for any and all help.
Bob C.
Old 08-11-04, 04:37 AM
mattison's Avatar
http://hbctechlit.honeywell.com/requ...m?form=69-1409
Here is the installation instructions for the IV. You will have to determine if you actually have 2 transformers or not.
If the link don't work just cut and paste it into your browser window or type it in.
Old 08-11-04, 04:49 PM
hvac4u's Avatar
pretty tricky working with dual transformers, may want to get a tech to wire it up, save burning a transformer or worse
i woould get common off the same transformer i got R from
