Gas floor furnace replacement options
Old 09-13-04, 10:47 PM
What I have:
1939 built- 1 story wood frame house with crawlspace.
Located in Long Beach, California.
I have no A/C and use a programmable thermostat for the furnace.
Near as I can tell, the furnace is original equipment.
Single floor furnace vent, right in the center of an 840 sq ft house.
Attic big enough for ducting, if needed.
Walls are recently insulated with R13, attic is about halfway insulated.
Just put in new energy effic windows and have sealed for air leaks.
I am probably over-due for a replacement of this furnace and would like some thoughts on the best options. This is a very small house and I'm not keen on spending huge amounts of money, given that I live in a fairly temperate climate. So far, I see two ways I could go about this - put in a new furnace that is more wall based (the current vent sits in the bottom of a wall - with a hall on one side and the dining room on the other side.) With a fan in the unit to force the heat more out into the rooms. 2nd option would be to run ducting through the attic and cut 6 ceiling registers in.
I am considering doing a small furnace and A/C unit, even though we would only use the A/C for just a few unbearable days in the summer. But it also seems like a waste, so I'm torn......
Any thoughts would be greatly appreciated!
Old 09-14-04, 04:15 AM
mattison's Avatar
If you have room in the attic just put it all up there. Furnace and ducting. You then also gain a closet in the living space.
Old 09-14-04, 08:47 AM
The furnace is actually under the house, in the crawl space. Which is a bummer because I would kill for more closet space....
The only real problem with putting a unit in the attic is that there is no gas line run up into there. The only way I see to get one is to run it up the side of the house, otherwise I would be opening up the middle wall inside from top to bottom to run the line through it.
Old 09-14-04, 09:29 AM
Ed Imeduc's Avatar
Received 1 Vote on 1 Post
Wink
Id go for the attic for the furnace there. You can run the line up the outside and paint it. You wont see it. Are fish a flex line up in that wall. You dont have to open the wall up.
ED
Old 09-17-04, 05:03 PM
hvac4u's Avatar
run the gas line up a corner of a closet, or with the lineset to the outdoor unit
