furnace fan keeps running!
Old 09-25-04, 08:29 PM
cprevost
I have a carrier incuction type gas furnace. Occasionally the blower fan will keep running even when the heat kicks off. It will only stop if I turn off the heater and turn it back on again. The on/off switch interupts the electrical supply to the heater. The induction fan is rattling noisily too. I don't know if that is related.
Old 09-26-04, 07:13 AM
hvac4u's Avatar
the blower problem is probably a stuck relay or fan limit switch depending on age. how old is it?
the inducer motor bearings are probably making the noise you describe
Old 09-26-04, 10:46 AM
cprevost
It is around 1978 or so. I found the adjust for the limit switch. It has a dial that you rotate to adjust the shut off delay. I set it for the shortest delay. Is there a way I can test the unit to see which is the problem? Thanks
Old 09-28-04, 11:22 AM
Ed Imeduc's Avatar
Received 1 Vote on 1 Post
Wink
If this is the old fan limit control you can reset the fan run temp right there. Dont reset the limit.
ED
Old 09-28-04, 03:52 PM
cprevost
ED
I'm not sure what you mean ED?
Thanks!
Old 09-29-04, 05:22 PM
cprevost
The only adjustment that I saw was to adjust the shutoff time. There weren't any other dials.
Old 10-06-04, 03:02 PM
cprevost
How do you set the fan run temp?
