Old Gas Furnace Blower Moter Won't Come On
Old 10-06-04, 06:43 PM
Chromedynasty
Old Gas Furnace Blower Motor Won't Come On
I have a 17 year-old Olsen gas furnace. The unit lights up fine, however the blower motor does not come on. This is the first time I have tried to fire it up this fall (it was functioning fine last year). I have checked for power at the motor and there is. I am a new homeowner and do not have experience with this type of furnace.
I can't seem to find any postings with this particular problem. Any comments would be greatly appreciated. Thanks in advance.
Old 10-07-04, 01:08 PM
mattison's Avatar
Try giving the fan motor a little push and see what happens.
Old 10-07-04, 02:22 PM
Chromedynasty
Thanks for your response. I've tried rotating the motor, with no results. I've tested for power at the motor and there is. Could it be a defective fan control (the fan control senses heat from the heat exchanger and triggers the fan motor, correct?)? The "manual/auto" button on the fan control doesn't seem to do anything. Is there a way for me to test it? I guess I could wire the motor directly to a plug to make sure it's okay first. If it's working okay is there a way of rigging up the fan control to simulate a call for heat?
Thanks.
Paul.
Old 10-07-04, 02:42 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
If you have 110 volts there at the fan motor pull it out and get a new one just like it. When you turn that fan control to manual the fan should run for you.
ED
Old 10-07-04, 02:53 PM
Chromedynasty
Thanks Ed.
Two quickies:
1)Should I pull the motor and hook it up directly to power before I trade it in?
2)Is the fan control like a relay? I was thinking that if the motor passes the test could I just jump the relay to start the motor(?). If it starts up, then it'd be the fan control that needs to be replaced, correct?
Thanks.
Paul.
Old 10-08-04, 05:34 AM
mattison's Avatar
If you have line voltage at the motor it's not the relay. Get a new motor and capacitor.
