oil furnace fan
Old 10-15-04, 03:32 PM
bawade
oil furnace fan
how can i make my fan fun when i turn the fan switch to on? I have only two wires to the thermostat? Have a pellet stove and want to circulate the heat with the furnace fan?
Old 10-15-04, 04:46 PM
Ed Imeduc's Avatar
Received 1 Vote on 1 Post
Wink
Need more info here. What is the blower control now,a fan limit control?? On some of them they have a switch right on them to turn the fan on. or you can add a relay on the blower control and run a wire to the tstat to G for a for on at it. What do you have now ????
ED
Old 10-15-04, 05:13 PM
bawade
limit control is what i have
Old 10-15-04, 06:02 PM
Ed Imeduc's Avatar
Wink
Is that a fan limit control if so ,it can have the switch right on it if not . You can wire in a switch to turn the fan on there if you want. "IF you know electric "
ED
Old 10-15-04, 06:07 PM
bawade
any way to do it from the thermostat? the fan limit control dosnt have a switch just 2 red wires and 1 black. rather do it from the thermostat then wouldnt have to go to basement.
Old 10-16-04, 04:32 AM
KField's Avatar
You need to get a third wire to the thermostat location and install a fan center relay on the furnace. Many furnaces come with the fan center already installed so you will need to study what you have before going out to buy more parts.
Ken
