Wiring Diagram for Lennox G8Q3 - 90000BTU
Old 10-16-04, 05:02 PM
Smelly Basement
Does anyone have a wiring diagram for this old furnace? I have installed it in my garage and have no wiring diagram as a guide as I try to bring power to it.
Thanks
Old 10-16-04, 05:07 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Have it just what part do you need
ED
Old 10-16-04, 05:22 PM
Smelly Basement
G8Q3-90-2 Wiring Diagram
This is a used furnace that was provided to me with many of the wires disconnected but all apparently intact. I need to run 115V power in and connect relevant wires to the transformer, the blower, etc. I can handle the thermostat wiring once I buy one.
Thanks a lot.
Old 10-17-04, 04:31 PM
Canucklehead
G8Q3 Running Like a Charm
Mr. Imeduc thanks for e-mailing the furnace wiring diagram. I wired it up this morning, works like a charm. Cant' thank you enough. Dave in Calgary.
Old 08-27-09, 05:32 PM
D
Lennox G8Q3 Furnace Wiring Diagram
Hello,
I found that you have received the wiring diagram for the Lennox G8Q3 furnace in the past. If you still have a copy, it would be greatly appreciated if you could forward it to me.
Many Thanks,
Darryl in Vancouver
dhkado @ gmail.com
Old 12-16-09, 06:23 AM
7
Lennox G8Q3 wiring diagram
I am looking for a wiring diagram for the above noted furnace.
Installing in my garage. Thanks for any help I can get.
Terry in Edmonton
Last edited by hvactechfw; 01-15-12 at 10:15 AM. Reason: removed email address from the post
Old 09-23-10, 12:08 AM
A
I am also looking for the wiring diagram for the given Lennox modal G8Q3-90-2
I am also wondering what the part number of the main solinoid gas valve, My unit was converted to propane and the gas valve replaced, wanted to make certain the gas valve I have will work for my planned change back to natural gas.
Arjun
Old 01-15-12, 08:46 AM
P
Hi.
I am having problems with the same furnace (pilot light won't stay on.
Can you forward the wiring diagram to me (which I believe is available from a previous post)?
Thanks
Old 01-15-12, 08:49 AM
P
Looking for Wiring Diagram for Lennox G8Q3 furnace
Do you still have the wiring diagram available? Please and thank you.
