Gas furnace Pilot Light???
Old 10-24-04, 01:26 PM
cdeters
I have an old Sears gas furnace (wall unit) model 867. I cannot figure out how to relight the pilot light. Please advise.
Old 10-24-04, 04:44 PM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello: C.Deters. Welcome to the Do It Yourself Web Site.
Look on top of the gas control valve. May be or likely to be a round knob with the wordings OFF PILOT ON on the top of the knob. If so, rotate knob to PILOT position and press down on the knob.
Light pilot and continue to hold button depressed for about 50-60 seconds. After 60 seconds or one minute, allow button to riase back up. Be sure any thermostat used for the wall heater is turn off or to the lowest temp setting. Than rotate knob to ON. Turn on and or up thermostat temp and burner(s) sould fire up.
Be advise not all wall heaters are the same, have the same lighting methods, control valve with knobs and or thermostats on the wall, etc. Basic instructions provided above based upon very limited specific and detailed information you provided here.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas and or repair methods.
Kindly use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list of questions automatically.
Regards & Good Luck
Sharp Advice
Web Site Host & Forums Monitor
