oil furnace won't start
Old 11-06-04, 07:08 AM
Leigh62
i have an oil furnace that won't "catch"...it seems to want to go on..but won't
the line seems to be clear, filter is good...you start it up and it turns off within minutes but never actually heat coming on
Old 11-06-04, 07:24 AM
Ed Imeduc's Avatar
Wink
When was the last time it was serviced. New nozzle, oil filter ,burner cleaned, spark reset. What is pump Psi? Transformer checked? Did you bleed the pump?Need more info here so some one can help you. DONT KEEP HITTING THE RESET BUTTON.Till you get it to run right.
ED
