Trane Furnace will not restart
Old 11-08-04, 06:30 AM
kirchm1
Hi,
I have a Trane XV80 furnace that will not restart after the inital run. For example, when I turn the furnace on in the morning and set the t-stat at 72deg., it will work fine. But the next time the furnace kicks in, the igniter will light the gas for a few seconds then it quits. It will cycle like this anywhere from 2 to 4 times, and then just the blower will kick in and continue to run until the furnace is shut off at the t-stat. It has to be turned off at least 2 hours or more before I can turn it back on and get it to work right one time.
I have replace the igniter and tried a different t-stat. If anyone has any ideas I would greatly appreciate it.
Old 11-10-04, 04:53 PM
hvac4u's Avatar
try cleaning the flame sensor rod at the far burner from the ignitor. let us know what happens then
