whirlpool hail quaker furnace
Old 11-10-04, 12:01 AM
ace6819
my furnace model number is NUGI075DF01,it cycles on and of until it gets to temperature every 15 to 30 seconds.the fan limiter looks like its sticking and squeeking.should it turn smooth?
Old 11-10-04, 04:32 AM
mattison's Avatar
Can you tell if it's the burners that are cycling on/off, or just the blower, or both ??
The fan limit if you watch them turn as they heat up and cool down sometimes they will be a little jerky. They are a cheap replacement though if it's in question.
Old 11-10-04, 02:20 PM
ace6819
both fan and burners are on and when it cycles on and off every 15 to 30 seconds its the fan thats cut on and off.
thanks for replying.
Old 11-10-04, 04:47 PM
hvac4u's Avatar
does sound like the limit, possibly. if it is a dial type fan/limit, it may be set improperly. it should turn smoothly
Old 11-10-04, 06:49 PM
ace6819
it is adial fan/limit and it seems to be sticking.will it have to be replaced?
also what thermostat and air filter is best for this furnace?
Old 11-10-04, 06:56 PM
mattison's Avatar
So the fan is kicking on and off while the burner stays lit?
Like I said the limit switch is cheap but 1st jump the limit out temporarily and see if it still cuts in and out or not.
Old 11-10-04, 10:28 PM
ace6819
yes the burner stays lit but the fan cycles on and off every ten seconds till the house heats to where the thermostat is set.when you say jump the limit out temporarily do you mean bypass the thermostat?
Old 11-11-04, 04:20 AM
mattison's Avatar
Not the t-stat, the fan limit. If you are not into electrical much don't bother. Do you have a volt meter to see if you are loosing electric to the fan motor.
What I'm getting at is it's possible the fan motor could be going south and with a volt meter you could watch the voltage drop off if the fan switch is what's opening.
