Goodman furnace blowing fuse
Old 11-13-04, 11:08 AM
mistered39
Goodman model gmt 115-5 blowing 3 amp fuse on circuitboard. Prior to this problem replaced ignitor which had gone bad. Any way to determine where the problem is ?
Old 11-13-04, 06:35 PM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Question More Specific and Detailed Info Requested
Hello mistered39. Welcome to the Heating Furnaces forum topic and the Do It Yourself Web Site.
If the problem did not exist prior to replacing the hot surface ignitor, than during the replacement of the igntior something happened to cause the problem. Our problem is knowing more details and answers to questions, so we can help further.
Was there no problem prior with the furnace until the hot surface ignitor (HSI) was replaced????
Would also have to know what fuse it is of how many on the board and what system the fuse protects? Any devices on the furnace not working that where prior to the incident???
For additional information, problem possibilities and solutions, read the existing questions within this forum pertaining to furnaces and heating appliances questions & topics. The already asked questions and the replies offered within them contain almost all the required information needed.
Additional Suggestions:
Read the manufacturers web site for product information, problem possibilities, problem causes, problem solving methods, part locations, disassembly, reassembly, repair procedures, instructions, pictorials, schematics, all or part of which may be available online.
An excellent source for original replacement parts is your local retail appliance parts store, the local heating dealers and agents retail part stores. Bring the make, model and serial numbers. The info will help to determine the possible problem causes.
Heating Agents & Heating Furnace part stores sell replacement parts for almost every heater brand. The locations for the dealers, agents and retail part stores are listed in the phone book.
Be sure the electrical power to the appliance is turned off, the thermostat is turned down and the gas control valve is in the off postion before attempting any repairs. Always check for gas leaks whenever a repair includes any connection of a gas part, gas line or tubing or gas supply.
Retail heating parts dealers, heating agents and part supplers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Dealers are an excellent source for original replacement parts and are listed in the phone book.
Check back on your question several more times. Heating professionals and other members posting replies in this forum topic may offer you additional advice, ideas and or repair methods.
Kindly use the reply button to add updated additional information. Using the reply button moves the topic back up to the top of the list of current questions automatically.
Regards & Good Luck.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
