Goodman furnace problem
Old 11-17-04, 04:33 PM
maryvash
Please help. We have a goodman furnace model number GMP N 100-4. It is about 11 years old. We just bought this house so we don't have a manual or know any history of the furnace. The problem all started when our breaker blew. The furnace and our air compressor was on the same breaker. We flipped the breaker back on and the furnace worked fine for 1 day and then the breaker blew again and the furnace will not work right now. Now the furnace is on it's own breaker. What happens is the furnace has a hot surface ignitor that will light and stay on for 8-10secs. waiting for the gas valve to open and light the burners. The burners never light and the the ignitor turns off and then will do this sequence 2 more times. Then the furnace will shut down and the ignition module (computer) will blink 1 time. We have replaced the ignition module, transformer and gas valve. The gas valve gets 24v to it from the transformer but the burners are not working. Please help. Thank you mary.
Old 11-17-04, 05:03 PM
hvac4u's Avatar
hot surface glows, 24 volts to valve but no flame?
new circuit board, transformer and valve?
remove and clean the burners
then try this...
when the hsi is glowing and 24 volts on the valve, use one of those fireplace matches or a long lighter to attempt to light the burners.
if they light, the HSI is weak or improperly positioned
if not, check gas pressure and flow throught the valve
good luck
